What vaculush Vcuum oump do I have?
- Barnaclebill
- Vessel Info: Lindy Star
2004 Carver 360 Mariner
Volvo 5.7 Liter GXI Gas Engines - Location: Southport, North Carolina
- Has thanked: 1 time
BarnacleBill
Lindy Star
Twin Volvo 5.7L GXII-F
Southport, NC
- Been thanked: 601 times
Re: What vaculush Vcuum oump do I have?
- Barnaclebill
Lindy Star
Southport, NC
- Been thanked: 1180 times
Barnaclebill wrote:Source of the post I have a 2004 Mariner 360. My Vacuflush vacuum pump needs a rebuild. The toilet is a 706 with a separate vacuum pump. It has a white cover guard held on by two screws. I can't find an exact image or a part number on the pump. Anybody have any ideas?
BarnacleBill
What exactly is your problem? For sure the duck bills need replacing as mentioned. Mine lasted 10 years before I started having issues and now will changed them every 8 as a preventative maintenance routine. 4 duckbills and a new bowl seal should do the job. I did change the bellows on one but think that was overkill. Do have a set of duckbills and bellows on board just in case.
Much better to do this when you have time as opposed emergency repair in the middle of vacation.- Midnightsun
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- Has thanked: 469 times
- Been thanked: 1765 times
- does the pump run?
- does the pump eventually shut off?
- how long does it run for before shutting off?
- does it cycle on it's own periodically?
- will water remain in the bowl if you don't flush?
- if the pump is working and shutting off after it builds a vacuum, do the contents of the bowl evacuate when you push the pedal?
- when were the duckbill valves last inspected/replaced?
- why are you rebuilding the pump?
etc....
- Been thanked: 646 times
- rjr
- Vessel Info: 440 MY
- Has thanked: 25 times
- Been thanked: 9 times
Yes, the pumps run. (2 heads).
Yes, pumps shut off.
Pumps run 30 to 40 seconds before shut off - could be a little less.
Hardly ever cycle on their own.
Yes, water will remain.
Yes, full evacuation.
Duckbills were replaced approximately 5 years ago.
Duckbills on Admiral's head are making a "weet weet weet" noise just before shutoff. So I figured it was time to replace. Then I figured might as well do both.
Question: Do you know where vacuum generator for forward head is located? Are generators located next to each other on starboard side of engine room near aft head holding tank? I have a waste & water schematic - if anybody wants one shoot me a PM with your email.
