Gray water tank level
- Captdoug
- Vessel Info: Carver 42 SS 2006
Re: Gray water tank level
They were optional.
- Captdoug
- Been thanked: 1111 times
For most boats the grey water is just run or pumped overboard.
- bowfirer
- Vessel Info: 2004 Sport Sedan, Volvo engines (gas)
Hope this helps...
They are also usually an option and not always installed.
tomschauer wrote:Source of the post Not sure about the SS, but usually the waste tank gauges are either in the heads near the toilets or in the main electrical panel.
Do you have a breaker or breakers in your 12v panel for waste tank level?
- Carpediem
- Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
- Has thanked: 2 times
- Been thanked: 25 times
- Gerard Chuah
- Vessel Info: Carver 41 Cockpit Motor Yacht 2006
My aft black water display showed it was completely filled and now unable to flush! The forward toilet is fine. I still can't find the switch to empty the black water tanks. Anyway knows where they are likely to be?
I couldn't find them on the electrical control panels. Are they in the engine compartment?
Thanks for your kind help
Best regards
