Gray water tank level
Captdoug
Vessel Info: Carver 42 SS 2006
Postby Captdoug » January 6th, 2021, 10:32 pm
I’m a new carver 42 SS owner. How or where is the gauge that’s tells me how much water is in the grey water tank. I have read the owners manual but there’s no information on this.
Been thanked: 601 times
Re: Gray water tank level
Postby tomschauer » January 7th, 2021, 9:34 am
Are you sure you have a grey water tank?
They were optional.
Captdoug
Postby Captdoug » January 7th, 2021, 10:44 am
I just assumed there was one. But now that I looked in the hole I didn’t see a tank and there’s not a pump out cap on deck any where.
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » January 7th, 2021, 11:27 am
Lots of places a grey water tank was not required, just black water. Sometimes there's provisions in the boat for a tank to be installed, in case it is used in an area requiring one.
For most boats the grey water is just run or pumped overboard.
Postby tomschauer » January 7th, 2021, 1:33 pm
run the water in your galley sink. look for it to come out of a through hull above the water line, most likely very near the sink. If you see the water coming out the side of the boat, you have no grey water tank.
bowfirer
Vessel Info: 2004 Sport Sedan, Volvo engines (gas)
Postby bowfirer » February 1st, 2021, 8:01 pm
I'm a new Carver owner so I'm far from being an authority on these cool vessels. That said, when I voiced the same question to a pal of mine, he suggested that grey water might be automatically vented overboard as it's produced. Not so with the Black water though. I'm still hunting for the blackwater level indicator/gauge, assuming there actually is one.
Hope this helps...
Postby tomschauer » February 1st, 2021, 8:05 pm
Not sure about the SS, but usually the waste tank gauges are either in the heads near the toilets or in the main electrical panel.
They are also usually an option and not always installed.
Postby tomschauer » February 1st, 2021, 8:06 pm
tomschauer wrote:Source of the post Not sure about the SS, but usually the waste tank gauges are either in the heads near the toilets or in the main electrical panel.
Do you have a breaker or breakers in your 12v panel for waste tank level?
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Has thanked: 2 times
Been thanked: 25 times
Postby Carpediem » February 1st, 2021, 11:15 pm
On the 506 there are grey water sumps that the water form the showers and sinks drain too and then it is pumped overboard like a bilge is. There iare two tanks with pumps and float switches. On one of the panels there are a couple of manual sump switches that override the float switches. there are no gauges and also there are no deck ports to evacuate the tank like the black water tanks have.
Try to only boat where ducks don't walk
Malaysia
Gerard Chuah
Vessel Info: Carver 41 Cockpit Motor Yacht 2006
Postby Gerard Chuah » May 15th, 2022, 10:03 am
I have a Carver 420 MY. The indicator for the black water tank is located in the toilet cabinets and shows a lighted display of whether they are filled up or not.
My aft black water display showed it was completely filled and now unable to flush! The forward toilet is fine. I still can't find the switch to empty the black water tanks. Anyway knows where they are likely to be?
I couldn't find them on the electrical control panels. Are they in the engine compartment?
Thanks for your kind help
Best regards
