Mobil One Synthetic
- Has thanked: 467 times
- Been thanked: 1759 times
Re: Mobil One Synthetic
- Vessel Info: 1998 Carver 405
- Has thanked: 234 times
- Been thanked: 38 times
- denpooch
- Has thanked: 85 times
- Been thanked: 87 times
My 2005 - 6.0 Crusaders recommend 'not' using synthetic oil.
I use 15W40.
- Been thanked: 601 times
Synthetic Oils
Synthetic engine oils may be used in Crusader Marine
Engines. Synthetic oils must meet the Engine Oil
Requirements for Classifi cation and Viscosity listed
below. The use of synthetic oil does not permit the
extension of oil change intervals.
denpooch wrote:Source of the post If you check the owners manual, the manufcturer will give you the proper oil specs.
I use 15W40.
That may have been so at the time of manufacture (2005), but formulations have changed, and so has OEM mindsets. I suspect if you check now, that wording would be different.
- Been thanked: 1177 times
Agreed. Found it funny that Mercruiser was quite clear on NOT using synthetic oil in their engines way back. Oddly enough when Mercruiser started selling their own branded Synthetic oil they changed their minds and recommended it.
- Has thanked: 597 times
- Been thanked: 1275 times
Of course there are many opinions as to what to do, I have my own...I have used one or another 15w40 for years with absolutely no adverse effects, since they stopped the green Kendall....
The thread started with , should I start using synthetic oil now.......
- SunsetSteve
- Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing) - Location: Gananoque
- Has thanked: 30 times
- Been thanked: 19 times
- Has thanked: 75 times
- Been thanked: 1084 times
tomschauer wrote:Source of the post <snip the video>
I like that guy's videos. He does a pretty good job capturing the gist of the topic at hand. I am a big proponent of synthetic oils for a lot of reasons. I used to run a lot of turbochargers on engines and what they do to conventional oil is brutal. I also remember one time on a VERY cold winter day up north where my car was the ONLY one in the parking lot to start, and I was the only one with synthetic in the crankcase. I've also torn down engines after over a hundred thousand miles of heavy-duty use and found impressively little wear on bearings and cylinders after living in a synthetic bath.
However, synthetic is much more expensive than conventional oil and there are a lot of engine applications that could never take advantage of all the benefits. Obviously you wouldn't be starting your boat engines in -20F temperatures but the heavy-duty usage could justify it.
I used to work for a "very old school" mechanic who didn't even like multi-viscosity oils. I still remember one of his favorite quotes on the subject:
"The only thing I know that gets thicker when it gets warmer is puddin'. And I ain't putting puddin' in my engine!!"
