Mobil One Synthetic
Has thanked: 469 times
Been thanked: 1765 times
Re: Mobil One Synthetic
Postby Viper » January 23rd, 2021, 11:09 pm
Ya I wouldn't paint all boat engines with the same brush, especially recent builds. If they call for synthetic, that's what you should be using. You can use synthetic on older engines but they do just fine with a good quality dino oil at regular maintenance intervals.
Serendipity
Vessel Info: 1998 Carver 405
Has thanked: 234 times
Been thanked: 38 times
Postby Serendipity » January 24th, 2021, 8:48 am
Thank you Tom for the heads up on your 1998 engines :down: :usa:
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 87 times
Postby denpooch » January 30th, 2021, 9:23 pm
If you check the owners manual, the manufcturer will give you the proper oil specs.
My 2005 - 6.0 Crusaders recommend 'not' using synthetic oil.
I use 15W40.
Been thanked: 601 times
Postby tomschauer » January 30th, 2021, 10:59 pm
From Crusader Owners Manual
Synthetic Oils
Synthetic engine oils may be used in Crusader Marine
Engines. Synthetic oils must meet the Engine Oil
Requirements for Classifi cation and Viscosity listed
below. The use of synthetic oil does not permit the
extension of oil change intervals.
Last edited by tomschauer on January 31st, 2021, 10:27 am, edited 1 time in total.
Postby Viper » January 31st, 2021, 8:52 am
denpooch wrote:Source of the post If you check the owners manual, the manufcturer will give you the proper oil specs.
I use 15W40.
That may have been so at the time of manufacture (2005), but formulations have changed, and so has OEM mindsets. I suspect if you check now, that wording would be different.
Been thanked: 1180 times
Postby Midnightsun » January 31st, 2021, 10:11 am
Agreed. Found it funny that Mercruiser was quite clear on NOT using synthetic oil in their engines way back. Oddly enough when Mercruiser started selling their own branded Synthetic oil they changed their minds and recommended it. :banghead:
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » January 31st, 2021, 10:18 am
The advice has always been , when there is any doubt the best course of action is to consult your engine manual and follow the oil recommendations you find there......if that is done all should be well ....at the time the manual was printed they would have made their recommendations based on the engine build ( bearing and ring clearances, seals ) at that time period and if that is the engine you have then......
Of course there are many opinions as to what to do, I have my own...I have used one or another 15w40 for years with absolutely no adverse effects, since they stopped the green Kendall.... :-O.....
The thread started with , should I start using synthetic oil now....... :popcorn:
SunsetSteve
Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing)
Has thanked: 30 times
Been thanked: 19 times
Postby SunsetSteve » January 31st, 2021, 4:20 pm
Manual specifies SAE 40 over 50F (1983 Crusader). That is not readily available today. So we reach out, as here. :drunk:
Postby tomschauer » February 9th, 2021, 11:18 pm
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » February 10th, 2021, 9:16 am
tomschauer wrote:Source of the post <snip the video>
I like that guy's videos. He does a pretty good job capturing the gist of the topic at hand. I am a big proponent of synthetic oils for a lot of reasons. I used to run a lot of turbochargers on engines and what they do to conventional oil is brutal. I also remember one time on a VERY cold winter day up north where my car was the ONLY one in the parking lot to start, and I was the only one with synthetic in the crankcase. I've also torn down engines after over a hundred thousand miles of heavy-duty use and found impressively little wear on bearings and cylinders after living in a synthetic bath.
However, synthetic is much more expensive than conventional oil and there are a lot of engine applications that could never take advantage of all the benefits. Obviously you wouldn't be starting your boat engines in -20F temperatures but the heavy-duty usage could justify it.
I used to work for a "very old school" mechanic who didn't even like multi-viscosity oils. I still remember one of his favorite quotes on the subject:
"The only thing I know that gets thicker when it gets warmer is puddin'. And I ain't putting puddin' in my engine!!"
