Head raw water inlet location?
mikesparker
Vessel Info: 1985 3227 w/Crusader 220s
Has thanked: 28 times
Been thanked: 3 times
Postby mikesparker » April 21st, 2021, 6:33 pm
I'm dumb...can't for the life of me find the raw water inlet cock for head on my 1985 3227. Anyone? Please?
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 284 times
Re: Head raw water inlet location?
Postby buster53 » April 21st, 2021, 7:30 pm
It will be fairly close to the head, probably within 2-3 feet.
Carver is very good at hiding bilge openings...inside cabinets, under stairs, under berths, under carpeting, etc. Locate all openings, get a good flashlight and start looking. Most likely, it will be in the engine room.
mikesparker
Postby mikesparker » April 21st, 2021, 9:05 pm
Thanks for the reply. I can only trace the inlet hose to the starboard side, where it vanishes behind a panel of some sort...can't tell if it'll come off or not yet. BTW...the hose disappears going UP into the unknown...strange?
I looked in the engine room...nada...behind the vanity...nada. Why would a manufacturer hide a raw water inlet??? Seems kinda dangerous to me.
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » April 21st, 2021, 9:13 pm
Do you have a single head, or two? I had two (not a 3227) and the inlet was in the engine compartment just forward of the port engine.
mikesparker
Postby mikesparker » April 21st, 2021, 9:15 pm
I have a single head starboard side midships...it's about 7 feet from the forward engine room bulkhead to the aft head bulkhead.
buster53
Postby buster53 » April 21st, 2021, 9:35 pm
Again, look for hidden bilge openings
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » April 21st, 2021, 9:57 pm
Did you look under the mid cabin mattress if I remember that boat right there is some access there ?
Been thanked: 601 times
Postby tomschauer » April 21st, 2021, 10:01 pm
Usually the raw water intake thru hulls are fairly easy to find. Look in the engine compartment.
You should only have through hulls (out the bottom of the boat), one for each engine, one for the A/C, one for genny, if so equipped and one for the head(s). If you have the over board discharge option you would have through hull(s) for them also.
mikesparker
Postby mikesparker » April 21st, 2021, 10:23 pm
I'll take a look under that mattress...never occurred to me to check there!
mikesparker
Postby mikesparker » April 21st, 2021, 10:25 pm
I've located the engine and generator raw water intakes, (no AC) but not the one for the head. I'll take a look under that mid-berth mattress when I get home in a couple of days.
tomschauer wrote:Source of the post Usually the raw water intake thru hulls are fairly easy to find. Look in the engine compartment.
Users browsing this forum: Google Adsense [Bot] and 25 guests
