Head raw water inlet location?
- mikesparker
- Vessel Info: 1985 3227 w/Crusader 220s
- Has thanked: 28 times
- Been thanked: 3 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Head raw water inlet location?
Carver is very good at hiding bilge openings...inside cabinets, under stairs, under berths, under carpeting, etc. Locate all openings, get a good flashlight and start looking. Most likely, it will be in the engine room.
- mikesparker
I looked in the engine room...nada...behind the vanity...nada. Why would a manufacturer hide a raw water inlet??? Seems kinda dangerous to me.
- mikesparker
- buster53
You should only have through hulls (out the bottom of the boat), one for each engine, one for the A/C, one for genny, if so equipped and one for the head(s). If you have the over board discharge option you would have through hull(s) for them also.
- mikesparker
- mikesparker
tomschauer wrote:Source of the post Usually the raw water intake thru hulls are fairly easy to find. Look in the engine compartment.
