Main Breaker(s) diode?
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Re: Main Breaker(s) diode?
- tonyiiiafl
- tonyiiiafl
They're used that way for a few reasons; current regulating, though I don't think that's the purpose here, EMF management, and to protect against a reversed power source which is likely the case here, it'll trip the breaker. If you suspect a diode, remove it, then power up again and see if the breaker still trips. If it doesn't, your breaker is okay and you may have a bad diode or a revered polarity condition. Curious, do you have reversed polarity indicator lamps?
- tonyiiiafl
Viper wrote:Source of the post They are diodes. Take the information on them and punch that into an on-line electronics retailer.
Yea, this is likely the case. That would explain the three-pole breaker. Only two are used for providing power, the third one is forced to trip upon a reverse-polarity condition, which also forces the other two off.
You should fix that. You shouldn't rely solely on the diodes. It's likely you have old neon lamps that flicker, dim, and eventually stop working. Change them out with some LED indicators.tonyiiiafl wrote:Source of the post I do have reverse polarity lights. However they don’t really work.
- tonyiiiafl
