Main Breaker(s) diode?
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » September 18th, 2021, 8:51 pm
1994 390CPMY. Finally had one of the 30A AC breakers giver up the ghost, wont reset. I found 2 on AMAZON, so all set there. Now the main panel has 2 30A breakers, Shore 1/Shore 2. I also found 2 of those at Great Lakes Skipper (https://www.ebay.com/itm/402992950528) On my breakers are a diode on each main breaker. Does anyone have any reference as to what they are and where to find them? unsure if they are bad, but want to be prepared.
Re: Main Breaker(s) diode?
Postby Viper » September 19th, 2021, 8:39 am
Are you sure it's a diode? Is it also hooked up to an indicator light? Do you have a pic you can post?
tonyiiiafl
Postby tonyiiiafl » September 19th, 2021, 9:09 am
I will get a photo this afternoon, it jumps from one terminal to the other. The breaker failure was at the shore power inlet. The 30A push button reset would not sty in the closed position. Been weak for a tad, I just wanted to check the panel while I was ordering. Funny thing is I have one cord going into SHORE 1 power plug. IF I shut shore 2 in the panel, shore 1 panel breaker will not stay on. However, if shore main panel breaker is put on, 1 works and powers up all on shore 1. Hmmm..
tonyiiiafl
Postby tonyiiiafl » September 20th, 2021, 5:44 pm
Viper,
Pictures of the diodes. One on each breaker.
Postby Viper » September 21st, 2021, 7:01 am
They are diodes. Take the information on them and punch that into an on-line electronics retailer.
They're used that way for a few reasons; current regulating, though I don't think that's the purpose here, EMF management, and to protect against a reversed power source which is likely the case here, it'll trip the breaker. If you suspect a diode, remove it, then power up again and see if the breaker still trips. If it doesn't, your breaker is okay and you may have a bad diode or a revered polarity condition. Curious, do you have reversed polarity indicator lamps?
tonyiiiafl
Postby tonyiiiafl » September 21st, 2021, 8:25 am
I do have reverse polarity lights. However they don’t really work.
Postby km1125 » September 21st, 2021, 10:11 am
Viper wrote:Source of the post They are diodes. Take the information on them and punch that into an on-line electronics retailer.
Yea, this is likely the case. That would explain the three-pole breaker. Only two are used for providing power, the third one is forced to trip upon a reverse-polarity condition, which also forces the other two off.
Postby Viper » September 21st, 2021, 9:44 pm
tonyiiiafl wrote:Source of the post I do have reverse polarity lights. However they don’t really work.
You should fix that. You shouldn't rely solely on the diodes. It's likely you have old neon lamps that flicker, dim, and eventually stop working. Change them out with some LED indicators.
tonyiiiafl
Postby tonyiiiafl » September 22nd, 2021, 3:01 am
I agree. They flicker and all. I need to research as to what is in there.
Postby Viper » September 22nd, 2021, 6:48 am
Look for 120V LEDs. Usually a red and a green are used for each shore power line. You'll need to know the diameter of the hole they mount into. I bought enough LEDs to replace all the 12V and 120V lamps in my panel as 3/4 of them don't work. Wanted to do that this summer but never got around to it, enjoyed the boat instead!
Return to “Electrical”
