95 Carver Mariner 330
Cooperlogan
Vessel Info: 1995 Carver Mariner 330
twin 270hp
Postby Cooperlogan » September 30th, 2021, 4:42 pm
asking if both engines are the same rotation
does this confirm the port eng v drive changes the prop to go counter clockwise
Also if both engines are the same rotation does that mean that distributors are identical
new forum registered today
thanks for feed back
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Re: 95 Carver Mariner 330
Postby ColRon » September 30th, 2021, 5:17 pm
Cooperlogan, Congratulations and welcome aboard! it would help greatly if you let us know what engines and v-drives you have.
Ron
“Escape Plan”
Murray, KY
:usa:
Postby Viper » September 30th, 2021, 5:34 pm
Welcome aboard. Ya more info would help, though for that vintage it's likely they are standard rotation engines.
Cooperlogan
twin 270hp
Postby Cooperlogan » September 30th, 2021, 7:05 pm
crusader 350 cu 270 hp
borg Warner v drive
I am pretty sure they're both standard rotation I'm going to check this weekend for sure
Cooperlogan
twin 270hp
Postby Cooperlogan » September 30th, 2021, 7:09 pm
The starboard engine keeps cutting out when trying to plane
There are pm's get up to about 2800 and then drop the 15 and then back on forth back on 4th
I have swapped carburetors coils and switched gas tanks
I have a fuel pump and distributor left to check
Any help would be greatly appreciated
Been thanked: 1111 times
Postby km1125 » September 30th, 2021, 10:51 pm
I'd start with fuel issues first... they are much more likely than other things. Have you checked/changed the filters (ALL of them?) When you switch gas tanks does it still go through the same filters?
Cooperlogan
twin 270hp
Postby Cooperlogan » October 1st, 2021, 6:08 am
Yes when switching tanks it goes through the same filters And yes I have changed all filters twice Fuel pump pressure is little over for 4 PSI
but that is Sitting at the dock I have not checked fuel pressure while underload yet
I am thinking of changing the field pump so that will be eliminated
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » October 1st, 2021, 11:00 am
I have the same vessel. My Crusaders are counter rotating. Look at the model number of each engine. They are probably CM350R and CM350L. The "R" or "L" at the end of each number means Right or Left. When you say 350, do you mean 5.7 XL, or the 350 XL? That engine RPM drop is fuel issues 90% of the time. Draw some fuel out of the bottom of the tank, an let it sit in a clear jar for a while. You will see if there is water in the fuel. Are you running with ethanol blended gas? These engines hate that. Welcome aboard, you have a great boat! 8-) er
Cooler By The Lake
Cooperlogan
twin 270hp
Postby Cooperlogan » October 1st, 2021, 4:12 pm
Thanks for all the feedback From everyone so far
Cooler - My engines are 350XL crusader 270 horse
I switched the starboard engine to the port tank but I am not sure the switch actually went through Since I never realized I could switch tanks before
I always thought they were just shut off Bells under the diner seat is dynamic is that where yours are or and have you ever switched tanks
Cooperlogan
twin 270hp
Postby Cooperlogan » October 1st, 2021, 4:13 pm
Has anyone ever had a problem like this and the distributor pick up being being bad
