1995 325 Muffler blown
- rbutler1959
- Vessel Info: 1995 Carver 325, Twin 350 Crusaders
- Has thanked: 2 times
Thanks…
Re: 1995 325 Muffler blown
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
267-982-2192 John Boatman
Apparently they got all the prints/drawings for all the Centek stuff when they went out of business. When I had to replace two fiberglass components in my exhaust system, they had one piece in stock and the other they created based on the original designs from Centek. Not cheap, but good quality and pretty quick turn-around.
Kyle
2002 Carver 396
Unless something just happened, Centek is still in business as far as I know. When did this happen?!KyleR wrote:Source of the post [url]....
Apparently they got all the prints/drawings for all the Centek stuff when they went out of business.....
- KyleR
2002 Carver 396
I misspoke.....as is typical!
I am trying to remember the back story I was told but it has been awhile. I think it was that when Carver went out of business, Centek at some point stopped making the parts and then Inetmarine got the prints and maintained the support. Or something like that.
Good catch - my memory ain't what it used to be!!
2002 Carver 396
Sorry, I forgot what you saidKyleR wrote:Source of the post....Good catch - my memory ain't what it used to be!!Unless something just happened, Centek is still in business as far as I know. When did this happen?!
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Aj325
- Vessel Info: 1996 325 Aft Cabin
350 XL's - Location: Manitowoc, WI
- Has thanked: 4 times
- Been thanked: 2 times
I have a 1996 325 aft cabin with Crusader 350’s. I believe the muffler drain is leaking on the Starboard engine.
I tightened it by hand, maybe 1/8 turn, but it is still seeping. Can you tell me if the seal is an “o” ring, or what brand the muffler is?
Currently the muffler is full of winterizing antifreeze, and I think I will wait until after launch so when I pull the drain it is just fresh water I need to clean up. My boat is in Manitowoc, Wi.
How did you resolve your leak on your muffler?
Thanks!
Allen Dietrich
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
Once I got the muffler out, I cut off what was left of the fiberglass tube from the muffler and simply put resin every where the tube connected to and put 3 layers of glass mat over it and soaked it with resin. the repair was perfect. Stronger than new.
The joint failed because it overheated due an almost fully clogged exhaust elbow.
I bought the connector from Defender Marine.
Users browsing this forum: Google Adsense [Bot] and 43 guests
