Heat Exchanger
carver355owner
Vessel Info: 1995 Carver 355. Powered by twin 454's.
Heat Exchanger
Postby carver355owner » August 1st, 2023, 5:35 pm
I just flushed my heat exchanger - a friend at the dock suggested using a product on the inside of the hose ends before sliding them back on and tightening the clamps to help with the seal. Has anyone used such a product? If so, what's it called?
Re: Heat Exchanger
Postby bud37 » August 1st, 2023, 5:47 pm
Welcome to the forum.....I use dish soap on the inside of the hose to assist in getting a tight hose on .......then just tighten the clamp......do not over tighten the clamp or it can cause a leak. Afterwards you will check all the fittings for watertight/function etc and adjust if necessary then good to go.
I would avoid gluing hoses on with sealant....remember you may have to take it apart again...... :-O
The beauty of dish soap is you can see it in the exhaust discharge so you know the system is functioning.
carver355owner
Re: Heat Exchanger
Postby carver355owner » August 1st, 2023, 5:56 pm
Thank you! I was thinking that sealing it would be a pain when it needs to be removed again... lol
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Re: Heat Exchanger
Postby KyleR » August 2nd, 2023, 11:00 pm
SeaBoard Marine recommends Rectorseal #5 on seawater connections in their videos and on their website. Helps the parts slide together easily, provides a good seal (along with clamps obviously) and yet the hoses will still separate easily when needed. I used it when I replaced most of my seawater hoses on both my main engines and have had no issues. YMMV
MV Verity
2002 Carver 396
Re: Heat Exchanger
Postby bud37 » August 3rd, 2023, 9:38 am
KyleR wrote:Source of the post Rectorseal #5
Unless I remember wrong is that not simply pipe dope designed for threaded fittings lube and seal.
KyleR
2002 Carver 396
Re: Heat Exchanger
Postby KyleR » August 3rd, 2023, 9:45 am
Basically, but I trust those guys at SeaBoard and it has worked well for me. Call it an "off label" use. ;-)
MV Verity
2002 Carver 396
Users browsing this forum: Google [Bot] and 28 guests
