Heat Exchanger
- carver355owner
- Vessel Info: 1995 Carver 355. Powered by twin 454's.
- Has thanked: 1 time
Heat Exchanger
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Heat Exchanger
I would avoid gluing hoses on with sealant....remember you may have to take it apart again......
The beauty of dish soap is you can see it in the exhaust discharge so you know the system is functioning.
- carver355owner
Re: Heat Exchanger
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 143 times
- Been thanked: 134 times
Re: Heat Exchanger
2002 Carver 396
Re: Heat Exchanger
KyleR wrote:Source of the post Rectorseal #5
Unless I remember wrong is that not simply pipe dope designed for threaded fittings lube and seal.
- KyleR
2002 Carver 396
Re: Heat Exchanger
Basically, but I trust those guys at SeaBoard and it has worked well for me. Call it an "off label" use.
2002 Carver 396
