Recommendations for Manual Oil Extractor Pump?
JeffandErin
Vessel Info: 1984 Carver 3607 Aft Cabin
Been thanked: 2 times
Postby JeffandErin » September 24th, 2023, 10:19 pm
I bought one off Amazon and it turned out to be junk. Dasbet 9L. It would not maintain the vacuum and I had to constantly pump to extract the oil.
Does anyone have any recommendations for a good extractor pump?
Been thanked: 1180 times
Re: Recommendations for Manual Oil Extractor Pump?
Postby Midnightsun » September 25th, 2023, 4:33 am
Pella and Mityvac are both good reliable brands. Have had both and still do, never had an issue. The Pella has to be 20 years old by now.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 487 times
Been thanked: 206 times
Postby pepmyster » September 25th, 2023, 7:03 am
Second the Mityvac. Had mine since I started boating. Great product!.
https://www.grainger.ca/en/product/p/WW ... lsrc=aw.ds
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » September 25th, 2023, 7:20 am
I do it for a living so speed is important for me and I find the manual pumps to be too slow. For that reason I prefer an electric system like the Jabsco (pail model), it extracts oil from an engine in a matter of a few minutes. I changed out the original hoses and clamps with better product, and replaced the pail with a regular 5 gallon one, with those mods it's the best for me. They're more expensive but I've done thousands of oil changes and it's still going strong, I think I've replaced the impeller once. I don't use the reverse function for emptying but it sure comes in handy when filling an engine with little clearance above the rocker cover to get a jug of oil in there, and it's way easier for filling large diesel engines.
JeffandErin
Postby JeffandErin » September 25th, 2023, 7:23 am
thank you all for your invaluable feedback
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » September 25th, 2023, 9:13 am
Pela the larger one, 14l will do both engines, still have it .....lasted for years now, if you are not in a hurry these are great....can be used anywhere as well as they are manual/vacuum ( no wires, clips, pumps, impellers, batteries etc ), think past the boat,..... lawn mowers, tractors cars etc.
plittle2005
Vessel Info: 1992 Carver 350 Aft Cabin
Has thanked: 16 times
Been thanked: 36 times
Postby plittle2005 » September 26th, 2023, 10:25 pm
FWIW, low-tech solution: https://www.walmart.com/ip/Jahy2Tech-Fl ... om=/search $14.95
This has 3/8 ID hoses that fit right over my dipstick tubes, and I pump oil out of my twin 454's into a 5 gal. bucket. Takes about 10 minutes total to do both engines, Discard the little pump, and the filters, into a drawstring plastic bag, put the lid on the bucket (add the genset oil if appropriate) and take it to the disposal site. No muss, no fuss, no spills
Then when you go to Walmart for your Rotella 15w-40 & filters the next fall, just pick up a new pump and you're good to go!!
