Replacing 396 salon door tracks
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 130 times
- Been thanked: 127 times
Also, this may not the only way to do this, but it definitely worked great for me and was overall a pretty easy job. A little convoluted, but it seems most boat jobs are!
I just wanted to document it and put it out there for others and also get into a little more detail than the original FB post.
So the first thing I did was remove the seating on the flybridge over the sliding salon door. The backs of the seating just slide upward and out. No screws or hardware to deal with.
2002 Carver 396
- KyleR
2002 Carver 396
Re: Replacing 396 salon door tracks
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
One note, on the top rail there were four Starboard spacers under the rail held on with two screws each. You do not need to remove those spacers before removing the door. That can be done later.
Also, here some part numbers that I found on the bottom edges of the door. I called this company and they are still in business and were the original supplier for these doors to Carver. They now have a better design with rollers on the lower track (see below). Anyway, Bomon is working me up a quote and said they'll have it to me Monday to replace both tracks and all hardware including the new lower track with rollers. I'll keep you posted.
2002 Carver 396
- KyleR
2002 Carver 396
Note: he removed that little corner cover I highlighted in yellow. This does NOT need to be removed, and he said it is actually metal and was held on with so much caulk it bent. So just leave it alone.
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- Pura Vida
- Vessel Info: 93 Carver Mariner 330. 2X 350XL Crusaders
- Has thanked: 17 times
- Been thanked: 10 times
Users browsing this forum: Google [Bot] and 37 guests
