Replacing 396 salon door tracks
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Also, this may not the only way to do this, but it definitely worked great for me and was overall a pretty easy job. A little convoluted, but it seems most boat jobs are!
I just wanted to document it and put it out there for others and also get into a little more detail than the original FB post.
So the first thing I did was remove the seating on the flybridge over the sliding salon door. The backs of the seating just slide upward and out. No screws or hardware to deal with.
2002 Carver 396
- KyleR
2002 Carver 396
Re: Replacing 396 salon door tracks
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
One note, on the top rail there were four Starboard spacers under the rail held on with two screws each. You do not need to remove those spacers before removing the door. That can be done later.
Also, here some part numbers that I found on the bottom edges of the door. I called this company and they are still in business and were the original supplier for these doors to Carver. They now have a better design with rollers on the lower track (see below). Anyway, Bomon is working me up a quote and said they'll have it to me Monday to replace both tracks and all hardware including the new lower track with rollers. I'll keep you posted.
2002 Carver 396
- KyleR
2002 Carver 396
Note: he removed that little corner cover I highlighted in yellow. This does NOT need to be removed, and he said it is actually metal and was held on with so much caulk it bent. So just leave it alone.
2002 Carver 396
- KyleR
2002 Carver 396
The door "stops" for these doors turned out to be nothing more than a screw that was screwed into the fiberglass just past the lower and upper tracks. Not surprisingly, the screws were bent and the fiberglass was cracked. So I bought a rubber door stopper at the local hardware store and installed it as shown below. Much nicer and more robust! And it is 100% concealed once the cabinet is back in place.2002 Carver 396
- Pura Vida
- Vessel Info: 93 Carver Mariner 330. 2X 350XL Crusaders
- Has thanked: 17 times
- Been thanked: 10 times
- KyleR
2002 Carver 396
Given how difficult our door had become to operate and the ongoing necessity for track lube (which then became a magnet for dirt and grime), we bit the bullet and bought the tracks. I basically justified the cost telling myself it was a safety issue!
Anyway, the installation was super easy - the holes in the tracks were predrilled and matched up perfectly. The only thing I had to do was install the little spacers on the top rail, but all the necessary hardware to do that was included. Just had to drill a few holes.
The only issue I ran into was one that I did not realize until I had the door reinstalled. The problem is that the four screws that attach the mating rail to the door stand a little "proud" under the door lip (see pic below with the screws circled in red). With the screws slightly protruding, when you slide the door the screw heads hit the rollers and cause the door to bounce and make a heck of a racket! And it was not smooth like I wanted.
So, off came the door again and what I was able to do was remove those screws and drill a slightly deeper countersink so that the screw heads were fully flush. Problem fixed! I attached another pic of the new lower roller track too.
After that, I put it all back together and now you can operate the door with a single finger! In fact my problem now is that I tend to throw the door open and slam it shut!!
2002 Carver 396
