Run a New Transducer cable on a 396 Carver
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Postby paulr » June 22nd, 2025, 4:30 pm
Does anyone have experience running a wire from the bridge dashboard to the bilge on a Carver 396 to install a new transducer? There must be somewhere that I could run a snake down from top to bottom.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Re: Run a New Transducer cable on a 396 Carver
Postby KyleR » June 23rd, 2025, 8:02 pm
On ours, under the bridge helm there is a large panel held on with eight screws. Open that and you have access to behind the helm electronics. You can then see where the throttle cables are run - which lead down to the engineroom. Maybe look where the throttle cables leave the bridge and then go into the engineroom and see where they enter there. I've never traced it out fully, but hopefully this gives you some ideas. Good luck!!
MV Verity
2002 Carver 396
paulr
Postby paulr » June 26th, 2025, 8:15 am
Thanks,
It makes sense as the throttle cables need a lot of room for them to pass through.
I will be at the boat in a few days and take a look in there.
Postby Viper » June 26th, 2025, 3:21 pm
I hope this is the model I have in mind...if you have the electrical panel on starboard side as soon as you go down the stairs into the cabin, the side wall up against the sliding door has a vinyl panel with 3 or 4 screws, remove that panel and you'll see where wiring and cables go from the bridge to the engine room. If I recall, there are 2 tubes that run forward to the helm behind that panel.
If that doesn't apply to your application, there's usually a wiring/cable race that runs up the port or starboard aft corner of the cabin where you remove a panel for access.
paulr
Postby paulr » October 21st, 2025, 8:43 am
I hired an Marine Electrician to to run a cable for a new radar system. What a pain. The lock ring that goes from the dash to the dome was too big to run through the hollow part of the aluminum support for the roof of the aft deck. He had to cut the ring off the fitting (because you cant cut the data cable) and order a special split collar from a guy he knew at Garmin and then come back to the marina and finish the job. All the extra time and running around used up all the money in my budget to figure out how to get a transducer cable from the dash to the bilge. So the transducer project is on hold.
I still havn't found a way to get a cable to the bilge from the bridge.
