(1988) Kohler 7.5KW Generator
Ondercin
Topic author - Scurvy Dog
- Vessel Info: 1988 carver 3607 AFT
Penetanguishene - Has thanked: 2 times
- Been thanked: 3 times
The genny runs fine on loads of 15amps or less, but anything higher causes the engine to run hard and shutdown.
Penetanguishene
- Been thanked: 654 times
Re: (1988) Kohler 7.5KW Generator
How about checking temp with the larger load compared to the no load, good water flow or another sensor shutting down the unit.
Ondercin
I've replaced the fuel pump with a new electric pump, and the fuel is flowing.
Penetanguishene
Livinthedream
Ondercin
Now the genny runs great, the only thing left to figure out is it's overheating a bit after 3 or so hours and not shutdown down automatically.
Penetanguishene
Ondercin wrote:Source of the post ....it's overheating a bit after 3 or so hours and not shutdown down automatically.
Are you saying that it is overheating but not shutting down automatically? If so, you have a faulty overtemp switch. Or do you mean it does shut down automatically?
What do you mean by "a bit" and how are you coming to the conclusion that it is overheating?
There are several things that will cause an overheat; t-stat, restricted raw water flow, faulty pump/impeller, air in system, clogged raw water circuit, timing, bad heat exchanger, bad coolant, low coolant....etc.
Ondercin
I am guessing the overtemp switch, but I haven't been able to test it yet... Perhaps on Saturday over a few beers!
Penetanguishene
